replacing the padding strips in a Helmet
ebikeerwidnes
Yes - Wear a helmet
which creates a problem - when I ride I sweat - especially in the summer and going up hills
and - after several years (since I broke my arm and my old helmet got badly dented) the padding strips inside are getting a bit crushed and - basically a bit minging
so I was think of replacing them - but the ones I find on ebay/amazon etc etc are mostly generic and don't have the same shapes as the current one
Ideally just a sheet of material and I can use the old ones to cut out the right shapes - would be just fine
but I can't find either a sheet of material - or a 'kit' with the right shapes
any ideas??
(sorry - yes I have tried the manufacturers - although I may try sending them an email - just thought of that)
thanks
I bought a kit on amazon, seemed to have the right bits
Replacement Foam Helmet Pads Universal Kit Bicycle Cycling Skating
but you remind me, at our local home improvement store, in the window insulation isle, there are pkgs of foam, of various widths & thicknesses, some with adhesive tape already attached. this is used to fill gaps in doors & windows. I'm thinking you might be able to re-purpose some of that
E
ebikeerwidnes
I would replace the whole lid if it got dented and its that old, you dont know if the structural integrity is still sound .
Its not dented - the helmet itself is pretty much perfect and only a couple of year old
it is just the padding strips that are a bit crushed by use
si_c
Wirral
The EPS foam breaks down over time, they usually recommend you replace it every couple of years or even the minimal protection is lost.
Drago
Flouncing Nobber
Poshshire
Most quality manifacturers sell replacement foam kits. Giro in particular sell very comprehensive OE pattern kits. Google is your friend.
E
ebikeerwidnes
I got mine from the LBS - but they don't seem to do replacement kits - I sent them an email but got a very unhelpful response
