Alloy Chain Ring for SR chainset.
Gunk
Oxford
There’s no guarantee that a s/h chainring will mesh with the chain/block combo you have due to wear.
Once you go 7 speed and below most stuff works fine. You can basically just mix and match
Ajax Bay
East Devon
Nothing in life is guaranteed, but I suggest there's every chance a used chainring will be fine. How will it not 'mesh' exactly? Only if the ring is worn out will there be a problem (any speed) and one can tell by looking at the teeth profiles in an image (say in an advert) if that is the case.
Edit: I see you might mean that the ring will be too 'wide' for the chain. Unlikely in practice. I have just measured an SR Apex chainring of similar vintage to the OP's crankset and the width of the tooth base is the same as both some Campagnolo rings (?2000) 135mm BCD and a Shimano 9 speed ring.
Ian H
I am an ancient randonneur, & I stop often for tea
East Devon
I have that same chainset on the fixed, though I run ⅛" rings. Spa Cycles have suitable TA rings listed.
